About keil random number
Hi,guys! I study about how to generate a random number recently,a lot of articles said "Linear Congruential Generator" is a frequently-used method!However,I used
the mothod rand() in the stdlib.h,which is a lib function of keil,I observed it seems as if it don't use this kind of method,do it???
  • "I study about how to generate a random number"
    If you've studied it, then you should be aware that there is no such thing as a purely software random number generator - the best you can achieve is pseudo-random...
    "I observed it seems as if it don't use this kind of method"
    What makes you think that?
    "do it???"
    Do you have a specific reason for asking, or is it purely out of curiosity?
  • I just want to know what kind of algorithm do the keil use?!
  • Why not just look at the library function for it?
    It exists in a few libraries (for the different memory models), but you can find one of them in C51BS.LIB in the module RAND.OBJ
    Just view it and you can see the exact implementation.
  • Keil produce 4 different toolsets for quite different architectures; I don't think there's any particular reason to beleive that they would all use the same algorithm?
    Specifically for C51, see: http://www.keil.com/forum/docs/thread3859.asp
  • The following is the code of the Rand() in the lib of keil:
    C:0x008E    AC0D     MOV      R4,?SRAND?BYTE(0x0D)
    C:0x0090    AD0E     MOV      R5,0x0E
    C:0x0092    AE0F     MOV      R6,0x0F
    C:0x0094    AF10     MOV      R7,0x10
    C:0x0096    7810     MOV      R0,#0x10
    C:0x0098    EC       MOV      A,R4
    C:0x0099    4D       ORL      A,R5
    C:0x009A    4E       ORL      A,R6
    C:0x009B    4F       ORL      A,R7
    C:0x009C    7004     JNZ      C:00A2
    C:0x009E    7CA5     MOV      R4,#0xA5
    C:0x00A0    7DA5     MOV      R5,#0xA5
    C:0x00A2    C3       CLR      C
    C:0x00A3    EC       MOV      A,R4
    C:0x00A4    13       RRC      A
    C:0x00A5    FC       MOV      R4,A
    C:0x00A6    ED       MOV      A,R5
    C:0x00A7    13       RRC      A
    C:0x00A8    FD       MOV      R5,A
    C:0x00A9    EE       MOV      A,R6
    C:0x00AA    13       RRC      A
    C:0x00AB    FE       MOV      R6,A
    C:0x00AC    EF       MOV      A,R7
    C:0x00AD    13       RRC      A
    C:0x00AE    FF       MOV      R7,A
    C:0x00AF    5010     JNC      C:00C1
    C:0x00B1    EC       MOV      A,R4
    C:0x00B2    64CC     XRL      A,#0xCC
    C:0x00B4    FC       MOV      R4,A
    C:0x00B5    ED       MOV      A,R5
    C:0x00B6    644C     XRL      A,#0x4C
    C:0x00B8    FD       MOV      R5,A
    C:0x00B9    EE       MOV      A,R6
    C:0x00BA    644E     XRL      A,#0x4E
    C:0x00BC    FE       MOV      R6,A
    C:0x00BD    EF       MOV      A,R7
    C:0x00BE    64CE     XRL      A,#0xCE
    C:0x00C0    FF       MOV      R7,A
    C:0x00C1    D8DF     DJNZ     R0,C:00A2
    C:0x00C3    8C0D     MOV      ?SRAND?BYTE(0x0D),R4
    C:0x00C5    8D0E     MOV      0x0E,R5
    C:0x00C7    8E0F     MOV      0x0F,R6
    C:0x00C9    8F10     MOV      0x10,R7
    C:0x00CB    EE       MOV      A,R6
    C:0x00CC    547F     ANL      A,#0x7F
    C:0x00CE    FE       MOV      R6,A
    C:0x00CF    22       RET
    but i can't read it clearly!
    Is there anyone can explain what the algorthim it uses?
    Or,is there source code of it?!Thanks a lot!!!!!!!
  • "but i can't read it clearly!"
    Seriously? Even a quick glance shows it's an LSFR implementation.
    If you don't get that right off the bat, play computer and write down the register values and all the effects of instructions interacting on said registers. Imagine objects of 16 or 32 bits in size being acted upon. Model that in C and it will boil down to a handful of C statements.
  • Even a quick glance shows it's an LSFR implementation.
    It's LFSR, to be exact. Don't let typos confuse the original poster even more. Here is the Wikipedia link:
    en.wikipedia.org/.../LFSR
  • There is an artical about keil generates the random with
    LSFR:
    http://www.keil.com/forum/docs/thread3202.asp
    what is :
    Masks for 3-bit galios LFSR maximum run length generator
    Masks for 8-bit galios LFSR maximum run length generator
    Masks for 10-bit galios LFSR maximum run length generator
    Masks for 32-bit galios LFSR maximum run length generator
    why masks the register?!
  • "There is an artical about keil generates the random with LSFR"
    Indeed - and its first paragraph gives a link to an article explaining the technical details!
    If you really want to get into this, then you are going to have to get down to some serious study - it is beyond the scope of this forum!
  • I understand the LSFR roughly,but seems that keil dosen't use it?!There is no some kind of masks for registers in LSFR?!
