hello I want to display weight on led display. Please send me code for saa 1064 interfacing with 8051f350 for display weight.
Thank you.
My bank account number at the Cayman's is:
1234567890,
email me at:
youareasucker@antitroll.com
If you want people to write your code for you, then you must expect to pay them in some way or another - money is usually the most convenient way.
In order for someone to write your code for you, they will require a detailed specification of your requirements, constraints, etc - simply stating, "saa 1064 interfacing with 8051f350 for display weight" is not anywhere near sufficient!
After studying your specification (and clarifying any issues), potential suppliers will give you a quote of how long the work should take, and how much it should cost.
The Device Database entry for the chip lists a number of Consultants having experience with this particular chip: http://www.keil.com/dd/chip/3682.htm
You can also search the entire consultants database: http://www.keil.com/condb/
Your chip supplier may also be able to recommend local design resources
etc, etc,...
.. as so often said
go ahead and send the exam project gift wrapped. Then wait for him to be hired as your assistant.
