Hello, I use a startup file which implements a configuration wizard. In this wizar 2 parameters (stack_size and Heap_size) are defined. But I want to define a variable in a header file and use that value in the assembly file instead. Therefore I try to include the file "sys_lpc.h" But when I compile my program, it returns the following error: error: A1167E: Invalid line start
Can you tell me how to include a defined variable in an assembly file?
Kind regards Sander Wiggers
#include "sys_lpc.h" Stack_Size EQU 0x00001008 AREA STACK, NOINIT, READWRITE, ALIGN=3 Stack_Mem SPACE Stack_Size __initial_sp ; <h> Heap Configuration ; <o> Heap Size (in Bytes) <0x0-0xFFFFFFFF:8> ; </h> Heap_Size EQU 0x00000400 AREA HEAP, NOINIT, READWRITE, ALIGN=3 __heap_base Heap_Mem SPACE Heap_Size __heap_limit PRESERVE8 THUMB ; Vector Table Mapped to Address 0 at Reset AREA RESET, DATA, READONLY EXPORT __Vectors __Vectors DCD __initial_sp ; Top of Stack DCD Reset_Handler ; Reset Handler DCD NMI_Handler ; NMI Handler DCD HardFault_Handler ; Hard Fault Handler DCD MemManage_Handler ; MPU Fault Handler DCD BusFault_Handler ; Bus Fault Handler DCD UsageFault_Handler ; Usage Fault Handler DCD 0 ; Reserved DCD 0 ; Reserved DCD 0 ; Reserved DCD 0 ; Reserved DCD SVC_Handler ; SVCall Handler DCD DebugMon_Handler ; Debug Monitor Handler DCD 0 ; Reserved DCD PendSV_Handler ; PendSV Handler DCD SysTick_Handler ; SysTick Handler
And you're sure we don't need to see the rest of the error message, right? Like: which line the message is about?
hi sanders,
have a look at a very similar request of mine at http://www.keil.com/forum/17010/
the solution was given by marcus by pointing me to infocenter.arm.com/.../index.jsp
regards, marco.
Hello Marco,
Thanks for your reply. I understand that I have to pars the assembly file thrue the c-preprocessor using the --cpreproc command line option. Is this correct?!
Where can I define the command line options? Do I have to configure it in the project settings in uVision?
Assuming you are using uVision - Yes!
And here's how: http://www.keil.com/support/man/docs/uv4/uv4_dg_adsas.htm
Thanks for the help. I got it working now!
