I am trying to operate a MMC memory card on MCBSTM32 evaluation board.
The sample codes is MCBSTM32_SD_File, I can’t find a library file(FS_CM3.lib) in the folder of c:\keil\..\RV31\lib\.. anybody has the file or know where to get it please tell me.
Best Regards TP
Are you using a free evaluation version?
If so, are you sure that this feature is supposed to be available in the free evaluation version?
No, I am using licensed software, overdue only, have requested new license, Are you sure this file will come with new license?
You have what commercial licenses?
Just the MDK-ARM, or the RL-ARM library. The RL-ARM library contains the flash file system.
You need to have license for RL-ARM
In that case, you should contact Keil support direct.
The forum is not the route to contact Keil support!
See: http://www.keil.com/forum/
