I'm making a program with the xc864 using the keil application but at some point I started to get the followings errors while I tried to program my micro:
" Content mismatch at address 0000H (Flash=EDH Required=02H) Content mismatch at address 0001H (Flash=B7H Required=0FH) Content mismatch at address 0002H (Flash=DCH Required=D6H) Content mismatch at address 0003H (Flash=7FH Required=78H) ... "
I've proved to comment independents parts of the program and the error disapears. So that I think that the problem is that my code is too huge for the micro.
How can I know what makes my code too huge? There is a way to get more free space for coding?
thanks
Making your program smaller is called optimizing.
On one hand, the compiler has a setting to turn on automatic optimization (for size and/or speed), but it is also a question of being a skilled developer.
Avoid the use of large library functions. Look at your code and see if you can rewrite some parts of the code to be more efficient. Is the code always using the optimum size for all variables?
Turn on generation of a map file, and look in the map file to see how large the program is, and the size of the different modules.
Thanks for the answer,
I've proved to comment the following include = #include <string.h> , and by now it seems it works as you can see the change in the memory map:
new code map= Program Size: data=77.2 xdata=0 const=0 code=3575 old code map= Program Size: data=77.2 xdata=0 const=0 code=4222
But now I've got another problem I used this include in order to compare lists of characters that I've have using the strcmp -->
for example =
if (strcmp(array,"ROK")==0) then ...
can any one tell me how I can compare an array of characters without using this function?
I don't believe that strcmp() is so large as indicated by the size change in the map file. You must have deactivated own code too.
strcmp() is a very small function. For a single compare of short strings, you can possibly do better with explicit character-by-character tests, but I don't expect that to be applicable for you.
Note that it isn't #include <string.h> that affects the size of the binary. It is the number of functions you call. The file string.h is just a menu, giving a list of available functions.
Look through the code and the map file and decide if there are code you can rewrite, or if you have any debug printouts using printf() or similar.
I've removed some printf, but after continuing writing code I've arrived at the same point : Program Size: data=102.1 xdata=0 const=0 code=4493
Looking on the datasheet I've confirmed that the xc864 just have 4k for flash programing, so that I must optmizate the program in order to introduce it but I don't what should I change or rewrite.
I've attached my c code and my map file in case somebody could give me an idea:
" href= "http://docs.google.com/View?id=d8twnwb_546gd8m9t5c">docs.google.com/View --> map file
The whole point of using functions is that the code is not repeated - a function occupies the same amount of code space whether it is called once or 1000 times!
The same applies to library functions; eg, printf: if you remove 999 printf calls, and leave only 1 call, then you will still need to have printf in the code.
Did you actually look at the MAP file, as suggested, to see exactly what is using up all your code space?
"Looking on the datasheet I've confirmed that the xc864 just have 4k for flash programing, so that I must optmizate the program..."
Before "oprimising" the program, have you actually considered whether a 4K part has any chance of being sufficient for your requirements?
At the end of the day, you cannot cram a quart into a pint pot!
I think your first job is to look at the LISTING file for your code. This will show you how much space one chunk of code uses versus another.
Simple things do not assign directly to an array element:
array_[0] = '1'; array_[1] = '1'; array_[2] = '1'; array_[3] = '1'; array_[4] = '1'; array_[5] = '1'; array_[6] = '1'; array_[7] = '1'; array_[8] = '\0';
Even if the array is is near space this is horribly inefficient.
I think the problem is you lack C programming experience, not that the processor memory isn't large enough. Your main function uses the bulk of your code space (0xCBC translates to 3260/4096), one function 80% of the code space (boggle). The real question is what do you need to do (minimal amount). Then map how to get there. It may be more prudent if you are in a hurry to instead 'use a processor more memory'. If you HAVE to use this processor, you must rethink your code.
I can give you a few clues. Why do you need to use sprintf at all? Why are you directly sending data to the serial port buffer in the main routine? Why are there no functions to handle repetitive tasks? (IE sending text to the serial port).
Stephen
This is a 8051 chip, i.e. a 8-bit processor that will suffer whenever it does 16-bit operations.
Don't use an int variable unless a char variable is too small. See for example the index variable in your strcmp2() function. By the way - have you checked if your function is smaller than the Keil function? If the Keil function is written in assembler it may win significantly from your indexed code.
Don't use a variable when a constant can be used. puts(array); In this case, the compiler will have to add code to initialize array[] with values before you send it. That consumes a huge amount of code compared to the use of the text constant "AT+JRES" stored directly in the flash.
And why do you later bother to clear the contents from array[]. Isn't it enough to initialize a uchar to 0, to remember that you have 0 valid characters in the array?
Don't use software delays generated by busy loops like:
while (i<100) i++;
The compiler can - if you turn on optimization - decide to remove the loop, since there are no side effect in the loop, other than to assign the value 100 to i.
Don't use magic constants when you don't have to. The C language has characters constants '\r', '\t', '\n', '\b', ... available. And if you really do have to use constants, use enum or #define to give them a name. Same code size, but easier to read - and no need to have a comment "10 en decimal = <LF>"
You did try earlier with:
sprintf(array,"AT+JSEC=1,1,1,04,1111");
But sprintf() is string-print-formatted and you don't have any formatting. The function when assigning a string to a character array is strcpy().
As noted, your main() contains a large number of repetitions that performs just about the same thing, but with different modem strings. Break out the functionality into a separate function, and just send the string constant as a parameter to this function. That will save you a huge amount of code space.
Create a function that converts a number represented as hexadecimal ASCII string to the numeric value. If you need to convert very large numbers, you can do it in two steps. Let one function convert the string into an array of bytes. Then you can either keep and use this array as is, or convert to 16-bit or 32-bit values.
Do you really need an array of 7 long, i.e. may any of the seven numbers be larger than 65535, the max range of an unsigned 16-bit integer?
Most developers normally write all comment in english. This has several advantages. You may post your code to an international forum and way more people will understand the comments and be able to help you. If you later work for a larger company, that company may have english as official company language, i.e. requiring that all official documents, design documents, ... has to use english. The reason being that you may have to work in a team with other developers from other countries. And big companies often buys and sells products and code libraries in deals with companies from other countries.
In the end - you will be easy to shrink your code to half the current size by just writing modular code and think about reuse.
