Hi, I used to use both Keil 2 and Keil 3 in my old computers, and they were fine.
Recently IT built me a new computer with x64 XP. But I cannot install Keil, either version, on it. It gives me error message like, "It is for a machine type other than current machine."
I really want to keep this new toy. Does Keil have any suggestion how to install the software?
Do you think it is a license issue or an OS issue?
If it is a licensing issue you should be able to use License management under the file menu to uninstall the license from your old machine and install it on the new machine.
www.keil.com/.../license_single_user.htm
If you need advice from actual Keil employess, you'll get it much faster if you use the proper support channels.
My advice would be to check for 32-bit compatibility mode settings in Windows and run the installer with the appropriate settings enabled.
