i want to compare two signals ,For example the ref signal and the feedback signal ,they can add to Logic Analyzer in two seperate area, it looks not good!
can you describe your problem in more detail?
When you are using i.e. Cortex-M3, the the tracing of two variables should be no problem, but you should switch off the PC sampling, and set the Timestamps to 64.
Data is always added in a seperate areas in Logic Analyzer, it cannot be displayed in the same area.
So, ... ...which controller are you using?
. BR, /th.
