Hi All,
The Software is configured for 10ms system timer(RTX System time), We have configured the watchdog.
Problem: The system will be runing fine for 1 hour and restart the system(if watchdog enabled) or gets running only in idle demon task (If watchdog is disabled after 1 hour.
Could you please help us in fixing the problem
to start with, if you are using a LPC2468/2478, please implement the recommendations of the errata sheets. see this thread:
http://www.keil.com/forum/docs/thread15346.asp
your system might reset because the task that serves the watchdog did not get CPU time promptly.
Thank you for your reply.
We are using LPC2378 Controller.
