Dear Sir
I use the evaluation version of uvision v4.11 to do some simulation. But I met a problem.
This is my first time to use tool, so in order to be familiar with tool quickly, I use the example S3F4A0K Flash provided by Keil. I want to use the simple simulator, I try to configure the setting of simulator like this : Go to Options for target -> Debug Press Settings next to Use Simulator Click Setting option
But when I click, there will be a error window - 'the selected device has no configuration options !'
And I check whether I choose the correct device under Options for Target -> Device. It seems I am right.
So can you help me to solve this problem ?
Thank you very much !!!
what is the difficulty here actually - don't do that, then!
Hi Sir
Do you means I have no need to do that ? So how can I configure the simulator ?
No configuration is required for your device.
Why do you call it an error window?
It is just informing you that there is nothing that requires configuring! Be glad!
