I just want to convert the intel .hex to .bin file.
I had downloaded the hex2bin but not able to create the .bin file even its showing message as Hex to Bin conversion was successfull. On Command prompt the command I am giving is ....c:\>hex2bin <one.hex> <two.bin>...............and its creating two.bin but its an empty file...
Pls advise. bmchheda1@yahoo.com
http://www.keil.com/support/docs/274.htm
Are you sure that you have a valid Intel Hex file?
Its a valid intel hex file...I would like to know that do I have to mention the .bin name or not...Tks
That is clearly stated in the instructions!
