i have proble with generating 1Sec delay..coe is below ..i have used 12Mhz crystal
#include "LPC21xx.H" void delay(void); void init_clock() { PLLCON=0x0; // the PLL is nt connected as the clock source for the processor PLLFEED=0xAA; PLLFEED=0x55; VPBDIV=0x00;//Pclk =12Mhz MAMCR = 0x00; // Any MAM function is disabled..i.e } /* the prescaler register is set to have the value 9999(=0x270f),so that the TC register is incremented after every 10000 clock cycles.So it should count upto 1200(=0x4B0) for 1sec delay with 12MHz supply as the Pclk. */ void delay() { T0PR = 0x0000270F; T0MR0 =0x000004B0 ; T0TCR =0x00000002; // the timer0 is activated T0TCR =0x00000001; // the timer0 is activated while(T0TC != T0MR0); T0MCR = 0x00000002; // Timer Counter will be in reset condition if the match between the MR0 and TC happens. T0TCR = 0x02; // when the match happens the Timer0 is resetted and it is again activated while the next delay is called } // with 12MHZ clock supply the time delay is cmng as 1sec if the delay value is 250000 // in this void main(void) { unsigned long dword=0xffffffff; unsigned char min_hand=0; init_clock(); PINSEL0 &= 0x00000000; // all the pins of port1 are selected as GPIO IODIR0 = 0xFFFFFFFF; // the pin 16 to 23 are configuered as the o/p pins. // IOCLR1 = 0xFFFFFFFF; while(1) { IO0CLR=dword; delay(); IO0SET=dword ; delay(); } }
www.8052.com/.../120313 (not specific to 8052)
