Something curious is happening with my USB HID device.
It is a Full-speed Device. The curious thing is that my VB software transfers 64 bytes of data (EP0 CONTROL TRANSFER) to the device only one time each 05 SOF signals of the USB line. So, instead of 64 KB/s I am only having 64/5 Kb/s data transfer rate.
I have even set my VB software to run in High priority mode - So it has nothing to do with Windows priorities.
Would anyone have a clue how I can increase the data transfer rate ?
It's reasonable rate.
Control transfer which carries Set_Report() (HidD_SetOutputReport() on Win32 API), consists of three stages, SETUP, DATA and STATUS. Each stage takes a USB frame. Also at the start of the transfer, overhead of 1 - 2 USB frame.
1) interrupt OUT endpoint, instead of Set_Report() OR 2) Insert High-Speed (USB2.0) hub
Tsuneo
Hi, Tsuneo,
Ok. Thanks. Indeed you are right. I forgot that the 03 CONTROL TRANSFER stages take up 03 FRAMES. Strange that the HID specification says that it can reach 64 KBytes/sec date rate. Since, HID´s only use CONTROL TRANSFERS as DATA OUT, I don´t see how they can achieve 64 KB/sec.
To use the OUT1PIPE, I would have to write a specific device driver, wouldn´t I ? I don´t know how to write Device Drivers. Would you know how I can achieve a higher data rate without having to write a specific device driver ?
Antonio
HID interface can have an interrupt OUT endpoint, optionally. The rate assumes this pipe.
The default HID device drivers on PC support the interrupt OUT pipe, on most of major OS (Windows, MacOS X, Linux hiddev).
For Windows, WriteFile() to the HID device is redirected to the interrupt OUT pipe, when the device has this pipe. HidD_SetOutputReport() and HidD_GetInputReport() always issue Control transfer, which carries Set_Report()/Get_Report(), respectively.
Even over an interrupt OUT endpoint on the HID interface, you need to send a large report at a time, to achieve 64 kBytes/sec (64000 bytes/sec). When your PC app sends 64 bytes report repeatedly, each WriteFile() call takes scheduling overhead of 1-2 USB frames (1-2 ms).
For example, declare 4 Kbytes output report on the report descriptor, and send this report in single WriteFile() call from the PC app. The PC host controller splits the transfer into 64-bytes packets (wMaxPacketSize of the interrupt OUT endpoint). The HID device receives the 64-bytes packets 64 times (64 x 64 = 4096) at the interrupt OUT endpoint. This transfer also takes 1-2 ms overhead at the first packet. But following packets are sent without overhead. (of course, bInterval of the endpoint is set to 1 ms)
If you want to have two or more output reports of different size, apply report ID to each output report.
Vey good hint. I will implement that and will let you know the results.
Thank you
My HID Device has an EP2IN pipe (64 bytes,Interrupt, 10 ms poll time) and EP1OUT PIPE (64 bytes, Interrupt, 1 ms poll time) and the EP0 PIPE.
I know it has been correctly configured because I have a USB PACKET ANALYZER and the enumeration does correctly define the EP1OUT pipe.
Even by defining a big report out (128 Bytes for a test) and using the writefile command has transfered the bytes to the device by using the control transfer instead of the EP1OUT PIPE. should I define a bigger report to have WRITEFILE and the HID drivers choose EP1OUT ? In that case, how can I define a big report in the report descriptor - My understanding is that afeter 95h I have only one byte to define the size of the output report ...
> My HID Device has an EP2IN pipe (64 bytes,Interrupt, 10 ms poll time) and EP1OUT PIPE (64 bytes, Interrupt, 1 ms poll time) and the EP0 PIPE. > Even by defining a big report out (128 Bytes for a test) and using the writefile command has transfered the bytes to the device by using the control transfer instead of the EP1OUT PIPE.
Sound like the EP1OUT PIPE is not recognized by the HID device driver on the PC.
Using USBView, read out the descriptors from the device. And post the result.
MS USBView on FTDI site www.ftdichip.com/.../usbview.zip
In fact that is very strange. The USB Packet analyzer (Plugged to another computer) does recognize the enumeration and tells me that the device has 02 endpoints. EP2IN AND EP1OUT. But the USBVIEW utility shows the EP2IN as the only pipe abailable. Not EP1OUT. If I inver the order in which the descriptors are sent to the host, then EP1OUT recognized by the host, but not EP2IN. It seems to be a wrong total number of bytes in the configuration descriptor declaration, but I recounted the number of byte and they are correctly described and asked for (29h = 41 bytes) Below please find the result of USB VIEW and the descriptors.
Device Descriptor: bcdUSB: 0x0110 bDeviceClass: 0x00 bDeviceSubClass: 0x00 bDeviceProtocol: 0x00 bMaxPacketSize0: 0x40 (64) idVendor: 0x0B6A (Maxim Integrated Products) idProduct: 0x7889 bcdDevice: 0x1234 iManufacturer: 0x01 iProduct: 0x02 iSerialNumber: 0x03 bNumConfigurations: 0x01
ConnectionStatus: DeviceConnected Current Config Value: 0x01 Device Bus Speed: Full Device Address: 0x01 Open Pipes: 1
Endpoint Descriptor: bEndpointAddress: 0x82 IN Transfer Type: Interrupt wMaxPacketSize: 0x0040 (64) bInterval: 0x0A
DESCRIPTORS THAT I USE (In Hexadecimal)
DEVICE_DESCRIPTOR 12 01 10 01 00 00 00 40 6A 0B 89 78 34 12 01 02 03 01
CONFIGURATION_DESCRIPTOR 09 02 29 00 01 01 00 E0 01
'INTERFACE DESCRIPTOR 09 04 00 00 01 03 00 00 00
'HID CLASS DESCRIPTOR 09 21 10 01 00 01 22 1C 00
'ENDPOINT DESCRIPTOR EP2IN 07 05 82 03 40 00 0A
'ENDPOINT DESCRIPTOR EP1OUT 07 05 01 03 40 00 01
REPORT DESCRIPTOR 06 A0 FF 09 01 A1 01 09 01 15 00 25 FF 75 08 95 40' INPUT REPORT LENGHT 81 00 09 02 75 08 95 80' OUTPUT REPORT LENGHT 91 00 C0
The wTotalLength field of the configuration descriptor is fine. But your interface descriptor claims just single endpoint :-)
'INTERFACE DESCRIPTOR 09 04 00 00 01 <---- bNumEndpoints, 02 for two endpoints 03 00 00 00
Report descriptor is revised as follows.
db 06h, 00h, ffh ; USAGE_PAGE (Vendor Defined Page 1) db 09h, 01h ; USAGE (Vendor Usage 1) db a1h, 01h ; COLLECTION (Application) ;; ---- common globals ---- db 15h, 00h ; LOGICAL_MINIMUM (0) db 26h, ffh, 0h ; LOGICAL_MAXIMUM (255) db 75h, 08h ; REPORT_SIZE (8) ;; ---- input report ---- db 95h, 40h ; REPORT_COUNT (64) db 09h, 01h ; USAGE (Vendor Usage 1) db 81h, 02h ; INPUT (Data,Var,Abs) ;; ---- output report ---- db 95h, 80h ; REPORT_COUNT (128) db 09h, 01h ; USAGE (Vendor Usage 1) db 91h, 02h ; OUTPUT (Data,Var,Abs) db c0h ; END_COLLECTION
It worked. I cannot thank you enough. You took a truck out of my back !!!!
Just a last question. How can I declare the output report as having, say, 4096 bytes - (Or 1000h Bytes). The field after the 95h can only be one byte long isn´t it true ?
Make it using "HID Descriptor Tool" from USB.org
HID Descriptor Tool www.usb.org/.../dt2_4.zip
char ReportDescriptor[28] = { 0x06, 0x00, 0xff, // USAGE_PAGE (Vendor Defined Page 1) 0x09, 0x01, // USAGE (Vendor Usage 1) 0xa1, 0x01, // COLLECTION (Application) // ---- common globals ---- 0x15, 0x00, // LOGICAL_MINIMUM (0) 0x26, 0xff, 0x00, // LOGICAL_MAXIMUM (255) 0x75, 0x08, // REPORT_SIZE (8) // ---- input report ---- 0x95, 0x40, // REPORT_COUNT (64) 0x09, 0x01, // USAGE (Vendor Usage 1) 0x81, 0x02, // INPUT (Data,Var,Abs) // ---- output report ---- 0x96, 0x00, 0x10, // REPORT_COUNT (4096) <-------- 0x09, 0x01, // USAGE (Vendor Usage 1) 0x91, 0x02, // OUTPUT (Data,Var,Abs) 0xc0 // END_COLLECTION };
IT WORKED !!! Thank you so much.
If you ever need anything please let me know.
Regards,
How can I define a second output report in the report descriptor so that I can also send only 64 Bytes (Only one packet) instead of always having to send the 4096 bytes of the big report ?
Define more than single input/output report using Report ID on the report descriptor.
char ReportDescriptor[36] = { 0x06, 0x00, 0xff, // USAGE_PAGE (Vendor Defined Page 1) 0x09, 0x01, // USAGE (Vendor Usage 1) 0xa1, 0x01, // COLLECTION (Application) // ---- common globals ---- 0x15, 0x00, // LOGICAL_MINIMUM (0) 0x26, 0xff, 0x00, // LOGICAL_MAXIMUM (255) 0x75, 0x08, // REPORT_SIZE (8) // ---- input report 1 ---- 0x85, 0x01, // REPORT_ID (1) 0x95, 0x3f, // REPORT_COUNT (63) 0x09, 0x01, // USAGE (Vendor Usage 1) 0x81, 0x02, // INPUT (Data,Var,Abs) // ---- output report 1 ---- 0x09, 0x01, // USAGE (Vendor Usage 1) 0x91, 0x02, // OUTPUT (Data,Var,Abs) // ---- output report 2 ---- 0x85, 0x02, // REPORT_ID (2) 0x96, 0x00, 0x10, // REPORT_COUNT (4096) 0x09, 0x01, // USAGE (Vendor Usage 1) 0x91, 0x02, // OUTPUT (Data,Var,Abs) 0xc0 // END_COLLECTION };
Each report precedes 1 byte report ID, for both of input and output.
Hi, tsuneo,
You should write a book on USB, my friend. It would certainly be better than the John Hide´s and Jan Axelson´s books.
Thanks once more
