Hello, I started a project using Advanced interrupt controller. HW is AT91SAM7XC256.
Source code:
void Ext0IrqHandler(void) { __asm { NOP } AT91C_BASE_AIC->AIC_EOICR=0; } int main(void) { /** BOOT SEQUENCE **/ /* PIO setup */ AT91F_PIOA_CfgPMC(); AT91F_PIOB_CfgPMC(); /* AIC setup */ AT91F_AIC_CfgPIO(); AT91F_AIC_CfgPMC(); // external interrupt 0 pAIC->AIC_IDCR = (1<<AT91C_ID_IRQ0); // external interrupt off in AIC pAIC->AIC_SVR[AT91C_ID_IRQ0] = (unsigned int)Ext0IrqHandler; // addr set pAIC->AIC_SMR[AT91C_ID_IRQ0] = (AT91C_AIC_SRCTYPE_POSITIVE_EDGE | 0x6); pAIC->AIC_IECR = (1<<AT91C_ID_IRQ0); // external interrupt on in AIC /** END OF BOOT SEQUENCE **/ while(1) { __asm { NOP NOP } } }
The problem is, that the processor enters into IRQ handler only once! It enters it, then goes back to main loop and then it absolutery ignore AIC's NIRQ and Pending flag. When it execute the handler once and it goes back to loop, the processor is still in Interrupt mode.. why? Please help. Milan P
You have an interrupt handler without specifying that it is an interrupt handler with the __irq keyword. Why?
IT WORKS NOW!!! Thank you, so much.
