I'm using uVision4 and C++ with LPC2478
class test { public: char s8; //placed at 0x4002C750 void* cp1; //placed at 0x4002C754 void* cp2; //placed at 0x4002C758 void* cp3; //placed at 0x4002C75C void* cp4; //placed at 0x4002C760 }
works
so i changed an Array
class test { public: char s8; //placed at 0x4002C750 void* cp1[4]; //placed at 0x4002C752 !! }
so this didn't not working it makes dabt error if I used cpl[0] the pointer is only the lower Bits.
after searching 2 days for the reason, I found the Compiler placed it to an unaligned address.
why? and how can i fixed it.
Start by calling Keil support directly, since this is a forum for end users.
Please keep us posted about this problem.
One more thing - are you sure that your C++ object is properly aligned? Remember that a C++ class can have own hidden member data.
In case the compiler have consumed 2 bytes internally before the s8 variable, then the pointer array does start n*4 bytes into the object.
