i must to simulate a 50MA to 1200MA load { at up to 20KHZ } in SOURCE.
can someone give me the idea what to be or code.
your urgent answer is wanted.
the only crazy thing here is your list of demands, ho Saddam.
"fabricca" like "fabricate" ?
can u ANSWER plz?
please explain how the subject is related to the content of your post, to start with.
What does "8-bit crazeyness" have to do with "simulate a 50MA to 1200MA load { at up to 20KHZ } in SOURCE" ??
First of all, Do you really mean 50MA - ie, 50 mega-amps; 5000000A - or do you mean 50mA - ie, 50 milli-amps ?
And how, exactly, do you want to "simulate" it? What will be the inputs to your simulation? What will be the outputs from your simulation? Why did you pick an 8051 to do it?
thk in answer.
my assignment is coal gas power station control in 8-bit. it is crazey ,,, yes?
yes it is 50.
i must have the inputs on the seriel pin { rs 233 ? } and see answer on display. i think i need fscanf and sprint.
do you want to help me plz.
You are the Monday Troll, and I claim my $5!
no answer here.
If all he is going to do is simulate - as he says - then it is enough to download some Spice code and run.
It's trivial to simulate a perfectly resistive potentiometer capable enough of handling these currents.
i have just seen spice.
looks very difficult but he said i i i must use it
i will learn.
thx.
you get $5 from mandy neil to?
you're a caricature of yourself, fabri. get lost...
the spice girls, I assume...
Recently seen Spice Girls? That would be february 2008 or earlier.
here is spice what i found.
en.wikipedia.org/.../SPICE
thx for the posts. one was even help to me.
you must have meant this one, actually:
en.wikipedia.org/.../Spice_girls
