We have a c++ class that cannot be compiled anymore since the compiler generates a "Class too large" message.
I decided to remove objects from it and to access them as pointers, ie:
I changed from:
class controller { Class1 Obj1; Class2 Obj2; Class3 Obj3; /* and methods accessing these objects */ void method() { Obj1.myMethod(); ... } }
to
class controller { Class1* pObj1; Class2* pObj2; Class3* pObj3; /* and methods accessing these objects */ void method() { pObj1->myMethod(); ... } }
Class1 Obj1; Class2 Obj2; Class3 Obj3; are then declared in another file and I called the following function at the very beginning to initialize my pointers:
Controller:InstallObjects() { pObj1 = &Obj1; pObj2 = &Obj2; pObj3 = &Obj3; }
So everything should work as before and the "class too large" error should be removed.
What happened is:
I am sure that InstallObjects is called before anything is accessed so pObj1, pObj2 and pObj3 are initialized and cannot be NULL
I followed the execution: pObj1->* calls are ok but at some point a pObj1->a_method() is not called ! The address seems to be bad (I cannot confirm as I don't have any emulator and I'm just debugging using printfs). My compiler version is 6.18 (the latest). I suspect a compiler or linker error...
Thanks a lot for your precious help,
Pierre
