Hello all expert,
Is is possible to use USB Wifi dongle (zd1211 Zydas chipset) with LPC2387/88 USB OTG combine with RL TCPnet or else? There are many binary drivers for Linux but I would like to embed to the Keil project so source code is required for porting. I just asking after do googling for the solution for long time. Is it all just a dream? if someone have any advise please share.
For the question why USB WiFi instead of WiFi module?, answer is very cheap price.
Thanks alot.
"For the question why USB WiFi instead of WiFi module?, answer is very cheap price."
Don't forget to include the cost of the software development in your estimation of the total cost of the different approaches:
The hardware may be "cheap", but if it requires 2 years of software development work, that could end up being an "expensive" solution overall...
A lot of "cheap" hardware designed for use with PCs relies upon having the majority of the software running on the PC.
