Error: Flash Download failed
hey can anyone help me???
i am using uVision3 and now i am encountering this error- Error: Flash Download failed - Could not load file 'C:\..\...\..\BlinkyCAN.ELF'?
My output window shows error 56 : cant open file.
wat am i supposed to do now? can anyone help me plss...
  • Check the paths in the project.
    Note that the message indicates a path that is three directories above the root directory:
    "C:\..\...\..\BlinkyCAN.ELF"
    And not only that - there are no path with three periods in a row.
    It would be more likely that it would look for the file:
    "C:..\..\..\BlinkyCAN.ELF"
    Don't you think all "can't find file" errors are best handled by first checking where the file are, and verify that you have the file, and that the tool looks at the direct location?
  • hey thanks for ur help!
    anyway, in the end, i managed to find the BlinkyCAN.ELF from another folder and put it into the designated folder. However, i realised that BlinkyCAN.ELF will just disappeared after i simulated with the simulator again. how come that will happen?
    And after i copy that BlinkyCAN.ELF into the designated folder and i load it. this come out:
    Erase Done.
    Programming Failed!
    A pop out will appear showing "Error : Flash Download failed - ARM7TDMI". I try to look at some forum and it told me to go to the Use Target Driver for Flash Programming---> Setting and change the Programming Algorithm to LPC2000 IAP2 256kB Flash but the same error popped out.
    what am i supposed to do next?
    Hope to hear from you soon!
    Regards,
    CJ
  • Anyway, i am using MCB2100 Flash and onboard LPC2129. :)
    Anyway, i try using Use Target Driver for Flash Programming---> Setting and change the Programming Algorithm to LPC2000 IAP2 512kB Flash but the same error popped out also.
