Hello, I would like to know how can i use delays in my program as there is no inbuilt delay for 89c2051. i want to know how can i decide delay timing when I am using 12 MHZ external crystal
With the 89c2051 running at 12MHz, one instruction cycle is 1us.
So you can write a delay in assembler using a multiple of instructions to build the time you require.
Use a loop if you want it longer.
You selected the wrong process as this is a derivative of the C51 the C251 is a different processor with a different ISA (although it can be made to run C51 code).
Timing can be implemented in many ways. It is best to know how precise your delay needs to be. You can use the timers built in for fairly precise timing delays. So you need to know your delay time and how precise it needs to be first. If you need to delay a few micro seconds. Use useless instructions. Ex
char temp; // 2-3 instruction cycles temp = 0; // 2-3 instruction cycles temp = 1;
Perhaps some definition of how much and how precise?
I've known many a project fail due to BAD timing delay design.
Stephen
HI.
whot delay du u need?
how acurate du u need?
u can use 8051 timer for good acurate timing for reletivly long delays or if u want short dlays u can use code.
but if u use code i advice u do not use it in c. u do not know whot machine code they're is so u dont know how acurate. four this u need asembler.
Always yo're freind.
Zeusti.
Hello Auther actually i am using C for programming .I am giving here smple code function for delay will it work?
void delay(unsigned int d_time) { unsigned int i,k=0; while(k<d_time) { for (i=0 ; i<=1000; i++); k++; } }
That depends on what you mean by "work"...?
In terms of giving a predictable delay, NO - it will not work!
The reason - and the solution - is given here: www.8052.com/.../162556
If you do continue to do this in 'C', you should declare the loop counter as volatile
