I am working on AT91SAM7SE512 based target board. The CPU has internal flash 512 KB. My Code size more than 256k. Keil flashing algorithm only seems to allow 256 kB. How do I flash?
It is written in datasheet that this microcontroller has 2 banks of 256kB each, so solution is to use AT91SAM7_256 for first bank and AT91SAM7_256_B1 for the second bank. You only have to add both algorithms for flash programming and first should be used for first bank and second for the second bank.
Thanks, In addition, I also have a bootloader.
