Not able to see the Peripherals window while debugging.
Hi, using AT91SAM9260 in one of my project and using MDK3.24 for compiling & debugging.
The problem is that I'm not able to see the Peripherals window while debugging, i.e. not able to see the different registers of peripherals.
But if I'm using AT91SAM7SE then I'm able to see the Peripheral window and all the registers values.
What may be the possible causes for this?
