Im able to compile and link a C++ application for the ARM7 LPC2378 using virtual methods.
However, when I try to run this application in debug mode, the debugger never reaches the "main". If I remove the virtual method (defined as pure virtual from which a class derives from) and use typical method definition, the application starts fine and im able to debug it.
Any ideas why this is not working?
I've tried theses option for the compiler: --cpp --no_vfe and these for the linker: --vfemode=off
... with no luck.
The tool versions number im currently using are as follow:
IDE-Version: uVision3 V3.62c Keil Elektronik GmbH / Keil Software, Inc. 1995 - 2008
Tool Version Numbers: Toolchain: RealView MDK-ARM Version: 3.22a Toolchain Path: BIN31\ C Compiler: Armcc.Exe V3.1.0.934 Assembler: Armasm.Exe V3.1.0.934 Linker/Locator: ArmLink.Exe V3.1.0.934 Librarian: ArmAr.Exe V3.1.0.934 Hex Converter: FromElf.Exe V3.1.0.934 CPU DLL: SARM.DLL V3.22a Dialog DLL: DARMP.DLL V1.40 Target DLL: BIN\UL2ARM.DLL V1.40 Dialog DLL: TARMP.DLL V1.40
