START167.A66 file with the correct settings
hello i am a student and i'm working to a project in which i am using a c163 evaluation board but i have a major problem and i can progress because of it, when i declare global variables i have problems if i try to run from flash memory.
It's a problem of configuration of memory, and i can't figure out how to do it write.
If you can give me a project with proper settings I would be very grateful.
Thank you very much
