i test http-Demo. But i get an error when i BUILD the target files:
linking... .\Obj\Http_demo.axf: Error: L6218E: Undefined symbol http_PortNum (referred from at_http.o). Target not created
i donÂ't found this referred file.
Can someone help me please?
make sure you include Net_lib.c and Net_config.c. In case you have different versions of RL-ARM installed, make sure you use all artefacts of the same version.
- Frank
check that: 1. you did not uncheck "http server" at "net_config.c", or remove the code that depends on it. 2. make sure the TCP .lib file is included in your project. the .o file you see is an object included in that library.
