I try to use external pin P5.6 to generate an interup but the interupt never apend. I use REVA board with STR912F MCU I'm working in debug
Here my code:
#include "STRx.h"
int delaycnt; int k; void interrupt_handler (void); ... ... function ... ... void interrupt_handler (void) { int i,l;
i=1; l=i; VIC1->VAR = 0; }
int main() { int i; int status = 0; int cote = 0; int size = 0; int suivant = 0; int timerst = 0; int timerval = 0; int timerval2 = 0; float volt; mg=0;
//init device initcpu(); //initialise GPI0 0 to 9
// Interupt init
// Clock for VIC SCU->PRR0 |= 0x0020; SCU->PCGRO |= 0x0020;
// Connect Pin P5.6 to the external interupt 1 SCU->WKUPSEL &= 0xFFF7; SCU->WKUPSEL |= 0x0030;
VIC1->VAiR[11] = (unsigned int)interrupt_handler; VIC1->VCiR[11] = 0x20; // enable interupt vector VIC1->VCiR[11] |= 0x0B; // specify interupt number VIC1->INTSR = 0x0000; // Generate IRQ instead of FIQ VIC1->INTER = 0x0800; // Enable interupt 11 du vic 1 VIC1->VAR = 0; // Acknowledge Interrupt
do { i =2; } while (i = 2);
code ... }
The port 5 is put in input modes as follow:
//GPIO5 init (pin 0-3 N/A) SCU->PRR1 |= 0x00080000; // release P5 reset SCU->PCGR1 |= 0x00080000; // clock gating P5 SCU->GPIOIN[5] |= 0x00; //P5.6 = intr 14 default GPIO5->DIR = 0x00; // Dir input on GPIO5 for pins 0-7
I put a breakpoint in the interupt code but it never hapend. What is wrong. It should work ???????
help please Mike
