When putting the following code into any .c file building the project makes the compiler stop and the process load for the C166.exe process is very high.
void buffer[64]= {"test the flash"};
I am pretty sure that this is a syntax error. However it took me some time to find the errornous line as the compiler was stuck and did not come up with anything.
I am not sure if this is a compiler bug. Could anyone test it?
IDE-Version: µVision V4.00a Copyright (c) Keil Elektronik GmbH / Keil Software, Inc. 1995 - 2009 Tool Version Numbers: Toolchain: PK166 Prof. Developers Kit Version: 7.00 Toolchain Path: D:\Keil_c166v7_demo\C166\BIN\ EC++ Compiler: EC166.Exe V1.09d C Compiler: C166.Exe V7.00 Assembler: A166.Exe V5.33 Linker/Locator: L166.Exe V5.25 Librarian: LIB166.Exe V4.26 Hex Converter: OH166.Exe V4.7a CPU DLL: S166.DLL V3.74 Dialog DLL: D167.DLL V2.52 Target DLL: BIN\UL2OCDS.DLL V1.23 Dialog DLL: T167.DLL V2.49
The syntax is incorrect as you stated and it also resulted in c166.exe having a high processing time on my side.
char buffer[64]= {"test the flash"};
results in a compile time for me of a couple of seconds.
