When I run the MDK-ARM Version 4.10 update (MDK410.exe), the content in ../Keil/ARM/RV31 is overwritten. I think it should be the ../Keil/ARM/RV40.
To fix this, I rename the overwritten RV31 to RV40 and copy back the RV31 from ../Keil/Backup.xxx.
This behaviour is also true for the previous 4.03a version (maybe for all 4.xx updates)
Doesn't it just go wherever you tell it?
Doesn't it come with a warning about "backing-up" existing installations?
Not sure whether I understand you right.
I currently have an installation of uVision4 it's under C:/Programme/Keil/... Within this directory I have ARM, uv3 and UV4.
Under ARM I have BIN, BIN31, BIN40, RV31 and RV40 (and some other).
I have the RV31 and BIN40 because I previously had an old installation of uVision3. And at the moment I will compile my projects with RV31.
When I run the MDK410.exe I will be asked whether I want to install into C:/Progamme/Keil.. and yes I want.
The second question is whether the installation script should make a backup. And yes, of course, I want a backup.
Where do you expect should the INC and LIB files for RV 4 should go? Into RV31 or into RV40.
I think they should go into RV40, but what do I see? They are in RV31.
BTW the programs in BIN40 looks into RV40 whereas the programs in BIN31 looks into RV31.
Is there something I do overlook, or misunderstand?
Yours sincerely Robert
