Hi,guys! I wonder that if my program runs to a breakpoint and hold,and i use a timer,is that timer will roll up,or hold as well as program running?!!!!!????
You'll have to look this up in your MCU manual. There are 3 options: 1) The timer keeps running 2) The timer is paused 3) One of the above depending on a configuration bit in a special register If I remember correctly, I've seen all 3 in different MCUs.
likewise
'debugger' often refer to a simulator
What do you mean three options?They can control simulator,not MCU?! I want to know if the timer continue when the simulatr run to a breakpoint? thanks!!!
why did you not say that in the first place?
fell sorry that i can't descripe my question!So,who can explain it now?!
