i am writing the code on i2c communication but it's not communicating betwwen the atmega169p and blr24f(external eepeom) the codw shown below #include<ioavr.h> #include<stdio.h> #include <intrinsics.h> #include <TWI_Master.h> //void write(unsigned char dadr,unsigned char mloc,unsigned char data); void main(void) { unsigned int data=0x02,read; //unsigned int j=000000000; PORTE=(1<<5);//sda; PORTE=(1<<6);//scl; USICR=0XA3;//USICR |=(1<<5);START+TWO WIRE MODE USISR=0X9F;//USICR &=~(1<<4);
USICR|=(1<<7);//startbit=1 USIDR=0X0A;//device address //USIDR=(j&0xFF);//lowerbyte USIDR=0000; USIDR=data; USICR=(1<<5);//stop bit
/* USICR|=(1<<7);//startbit=1 USIDR=0X0B;//device address //USIDR=(j&0xFF);//lowerbyte USIDR=0002; //USICR|=(1<<7);//startbit=1 read=USIDR; USICR=(1<<5);//stop bit */ while(1);
1. The purpose of this forum is clearly stated:
"The Keil Discussion Forum is an open forum where you may post questions and comments about Keil products." http://www.keil.com/forum/
Your post has nothing to do with Keil products.
2. The instructions for posting source code are clearly stated: www.danlhenry.com/.../keil_code.png
You haven't followed them, and don't even seem to have noticed that your posted code is illegible.
Is it any surprise, then, that your code doesn't work?
