Hi...
I have interfaced LPC2366 with vinculum VDrive Module - VDrive2 on SPI (SSP0)
after referring the datasheet of vinculum(DS_VNC1L_V201.pdf) for SPI communication they have mentioned
" The SPI interface differs from most other implementations in that it uses a 13 clock sequence to transfer a single byte of data. "
Hence in my code I have made the configuration for the same, but instead of getting proper Data I am getting garbage values.
The configurations done in my code are :-
// Init..... SSP void InitSSPUSB(void) { INT8U ucDummy; INT8U ucCntr; // Configure pins for SSP interface PINSEL3 |= 0x0003C300; // Power ON SPI control PCONP |= PCSSP0; // Set DSS data to 8-bit, Frame format SPI, CPOL = 0, CPHA = 0, and SCR is 15 // SSP0CR0 = 0x0007; SSP0CR0 = 0x0707; // SSPCPSR clock prescale register, master mode, minimum divisor is 0x02 SSP0CPSR = 0x02; // SSP0CPSR = 0xFE; // for LOW Speed max ... 400kHz // Loop till FIFO size for( ucCntr = 0; ucCntr < FIFOSIZE; ucCntr++ ) { // Flush RX FIFO ucDummy = SSP0DR; } ucDummy = ucDummy; // Configure SSEL pin output direction IODIR1 |= SSEL; // Pull the pin high IOPIN1 |= SSEL; // Enable SSE SSP0CR1 = 0x02; } // Receive data over SPI void TestSPIReceiveUSB( INT8U *SPIRxData, INT16U uiLenght ) { INT16U uiCntr; for( uiCntr = 0; uiCntr < uiLenght; uiCntr++ ) { // This is important if not then NO resposne SSP0DR = 0xFF; // Wait until Receive FIFO is empty while ( !( SSP0SR & SSPSR_RNE ) ); // Read SSP port data *SPIRxData = SSP0DR; // Increment address of the poiter to point to next byte SPIRxData++; } } void main() { // call SPI receive handler function TestSPIReceiveUSB((INT8U *)&SPIRxData[0], 8); // Call a function to display the received data on UART }
Does I am making a mistake in setting 13 clock sequence ( SSP0CR0 = 0x0707) to transfer a single byte of data ?
