Hi. I need some reference for start up file in keil uvision. some information about keil assemble code and about all of thing I need to I can writing start up file.
thank you.
what you need is:
* an existing file (example) * processor user manual (how does the processor startup?) * assembly manual
no magic wands here. read, learn, play.
Actually, the startup file is to do with the Compiler - not uVision.
Did it occur to you to look at the Manuals:
http://www.keil.com/support/man/
The one called the "Primer" would seem the obvious place to start.
It has a section about configuring startup code...
" ... writing start up file"
as Tamir says, it's most unlikely that you actually need to write the startup file - take one of the existing files, and just modify it to suit your requirements (it might not even need modification)
one more link:
http://www.keil.com/support/man/docs/gsac/GSAC_StrtupCodeARM7.htm
thsnk you for all reply. When I understand how can write start up file I will make a program that help people to write startup file!!!
IT's very necessry!:D
"IT's very necessry"
Is it?
Don't Keil give you enough with the provided examples?
See your previous thread on the same subject: http://www.keil.com/forum/docs/thread16418.asp
