PWM flash trouble
I try to create a simple PWM signal, I've unchecked "use memory layout from target dialog" from L166 Locate from uvision options and everything works perfect if i run from ram memory, but if run from flash memory the pwm signal doesn't work.
I've received some warnings
*** WARNING L22: CLASS RANGE NOT GIVEN IN INVOCATION LINE CLASS: NDATA
*** WARNING L22: CLASS RANGE NOT GIVEN IN INVOCATION LINE CLASS: NDATA0
so I use this code in Linker Control String
CLASSES (NCONST(00000h-03FFFh),&
NDATA (04000h-07FFFh),&
NDATA0 (04000h-07FFFh),&
SDATA (0C000h-0FFFFh),&
SDATA0 (0C000h-0FFFFh),&
IDATA (0FA00h-0FDFFh),&
IDATA0 (0FA00h-0FDFFh),&
BIT (0FD00h-0FDFFh),&
BIT0 (0FD00h-0FDFFh),&
BDATA (0FD00h-0FDFFh),&
BDATA0 (0FD00h-0FDFFh))
from L166 Misc.
Please let me know if u have a clue about this problem.
Thank you very much.
