I need (hourmeter) odometer, which will measure the hours of old tractor engine, If someone has an idea how to....
something like they have on youtube
Thanks advance ....
Apart from some implementations possibly having displays that look similar, "hour meter" and "odometer" are not similar terms at all.
An odometer is a device that records distance covered.
Is that what want, or do you really want something that records run time?
All you need is something that counts time whenever the engine is running - does your problem lie with counting time, or with determining when the engine is running, or what?
"something like they have on youtube"
There is such a vast and disparate array of diverse stuff on Youtube that the above is totally meaningless!
If you need an hour meter, buy a Hobbs.
You mean one of these?
www.aircraftspruce.com/.../hobbs.php
