Microporcessor Wont Recieve Data From Comp
My microprocesser wont recieve data from my comp, i've used hyparterm, telnet, and linkit-123
but none of them wont transemit data to my MPu. yet i see a recieve mode in the Link menu
why?
  • more words, please
    a few basic questions
    1) you do have a MAX232(equivalent) between the UART and the 'compensator', I hope
    2) do you get nothing or garbage if you constantly transmiy 'U'?
    3) are you cabled correctly (RS-232 cables comes in 'straight' and 'crossed') and you must use the cable that match yur connections at the uC
  • "My microprocesser wont recieve data from my comp"
    OK, so it's a pretty good guess that "comp" means "computer" here - but having to guess doesn't help.
    The more clear and complete you make your description, the more likely you are to get good replies!
    "i've used hyparterm, telnet, and linkit-123"
    Hyperterminal is a plain text terminal emulator;
    Telnet is an internet protocol;
    I have no idea what "limkit-123" is.
    Are you sure that you had all these tools correctly configured - speed, parity, handshaking, etc?
    "but none of them wont transemit data"
    How do you know that they won't transmit?
    Your first step has to be to determine where the problem is:
    Is the PC transmitting correctly?
    Is the data reaching the microcontroller's pins correctly (ie, correct & working cabling, correct & working RS232 transceiver, correct & working board connections, etc)?
    Has your software correctly configured the UART, etc?
    "i see a recieve mode in the Link menu"
    What is a "receive mode"?
    What "link menu"?
  • YEAAAAAAHHHHHH
    I fixde it bcoz teh cable was not in.
