Dynamic DNS
Dear all
I would like to ask if anyone able to implement "dynamic dns" support on LPC2368 using Keil's TCPnet.
The concept is, i ve web server build in LPC device and connect through the home ADSL router. Then i would like to monitor and control the LPC device from outside PC via web browser. The ADSL router often changes it's IP address, so i would like to use a free service such as http://www.no-ip.com or http://www.dyndns.com which giving fix dns to connect my LPC web server. (Something like off the shelf ip-camera feature)
I know that most ADSL router has this functionallity (dynamic dns) built in, but it's aimed for game sharing and might not suit to my application.
Any web link, sample application or knowledge base if you have please share.
Thanks alot.
Kom
  • no-ip publish their update API here: www.no-ip.com/.../
    dyndns is here: www.dyndns.com/.../
    "The ADSL router often changes its IP address"
    No, the router doesn't change it; the router has an IP address assigned to it by your ISP - so it is your ISP that changes it.
    "I know that most ADSL router has this functionallity (dynamic dns) built in, but it's aimed for game sharing and might not suit to my application."
    The application is irrelevant: it's just a matter of associating a name with an IP address - it makes no difference whatsoever what application is using the name/address!
    So, unless you really want to get into writing your own dynamic DNS update client, just let the ADSL router do it for you!
    And if the router doesn't have the client built-in, then just run a PC client on a PC behind the router.
