Hello all,
I have a project I need to do to pass a class and want you guys to do the work for me. And please do it ASAP.
The project needs to do video capture, analyze the scene, and compare the objects to a library of 'parts.'
I need to use an 8051 at 12MHz (1 MIPS) with no external RAM, and it must use a 1N4004 diode: axial thru-hole only.
Please post the schematics and Keil code as soon as possible.
Actually, I haven't been on this forum in a while, and just wanted to say 'hi' to all of you regular readers and contributors. I'm sorry I haven't bored you to death in a while. I'll try to contribute my tomes more often.
--Cpt. Vince Foster 2nd Cannon Place Fort Marcy Park, VA
Hello Captain,
Good to have you back. I took your role as rambler for a while, significantly improving your rambler to content ratio (I have at least one smart ass witness). However, if this is a weapon system, I'm out :-)
Thanks to for taking up my slack Tamir. (And no weapon systems are involved)
[add inane rambling here]
void support_the_inane( long *rambling ) { // too much commenting printf( "%s", rambling ); // comment on the obvious printing of the rambling }
... you failed to spot the obvious pointer-type error!
Tut, tut!
