Hi. my usart interrupt dont work correctly .when I chek it in the debugger the US_CR value from 0x1A1A chang to the 0x1A1B and after that the usart hang up!!
in other place in debugger when I chek ofter every interrupt the program doese reset! and I dont know why!!
I think hang up is for a lot of reset of program when a lot of interrupt occure.
It's very funny that if I say that if I deletion the
delay_ms(100);
in my program my Interrupt only work one time! not reset and not anything else! but only work one time and in secend time the interrupt occure the US_CR from 0x1A1A chang to 0x1A1B it's mean that the Rx ready bit in US_CR from 0 becom to 1! OOOK. pleas Help me .but If dont help me I hang up too!like my micro!
my start up is sam7.s are you think my problem is that I dont use another start up file .or i must chang it !!!
and thise is my code:
#include "at91sam7x256.h" #include "lib_at91sam7x256.h" #include "delay.h" void Usart0IrqHandler(void); int kk=70; int main (void) { volatile AT91PS_USART pUSART0 = AT91C_BASE_US0; int rx; unsigned int rxok; int errorcounter; *AT91C_PMC_PCER=0xC0000040; //Peripheral Clock Enable *AT91C_PIOA_ASR=0X0000003; *AT91C_PIOA_BSR=0X0000000; *AT91C_PIOA_PDR=0x00000003; //Disable I/O,PA5=RXD0,PA6=TXD0 *AT91C_US0_IDR =0xFFFFFFFF; //ALL OFF USART INTERRUPT DISABLE *AT91C_US0_CR=0x000000AC; //RESET RX & TX *AT91C_US0_BRGR=0x139; //BARD RATE:9600 *AT91C_US0_TTGR=0x00000100; //SET TIME GARD=0 AT91F_PDC_Open(AT91C_BASE_PDC_US0); *AT91C_US0_MR=0X8C0; //8bit,No,1Bit Stop,Asaynchron mode *AT91C_US0_CR=0x50; //ENABLE RX & ENABLE tx *AT91C_US0_IER =0x01; //rxbufer full interrupt is set *AT91C_AIC_IDCR=0x40; //DISABLE THE INTERRUOT ON THE INTERRUPT CONTROLLER AT91C_AIC_SVR[AT91C_ID_US0] = (unsigned int)Usart0IrqHandler; // Set the USART0 IRQ handler address in AIC AT91C_AIC_SMR[AT91C_ID_US0] =(0x00000007); *AT91C_AIC_IECR=0x40; *AT91C_AIC_FFDR=0XFFFFFFFF; while(1){ *AT91C_US0_CR=0x100; rxok=*AT91C_US0_CSR; delay_ms(100); *AT91C_US0_IER =0x4; } return 0; } void Usart0IrqHandler(void){ int rx; int i; volatile AT91PS_AIC pAIC = AT91C_BASE_AIC; unsigned int rxok; int errorcounter; errorcounter=0; kk=kk+1; rxok=*AT91C_US0_CSR; if (rxok && 0x1){ rx=(*AT91C_US0_RHR & 0xff); *AT91C_US0_THR=kk;//rx&0xff; } *AT91C_US0_CR=0x2100; *AT91C_US0_IDR =0x4; rxok=*AT91C_US0_CSR; *AT91C_AIC_EOICR =0x00; //end point of interrupt return; }
I set ox00 value in AIC_EOICR registry.It's right or or the problem is for it? thank's
Don't you already have a thread running on this?
http://www.keil.com/forum/docs/thread16333.asp
do you have enough IRQ mode stack space? does your controller end up in abort mode?
Hi man..I think if you help to solve peroblems is better to find plagiarism in thise site. ok?
Thans for reply me..very very thanks.
1-when I debug program ,I can see that all of the interrupt do correctly and interrupt back to program but after that it's hang up.
2-In the data sheet I can't find any thing about IRQ stack size!!! Is it set in start up file? How we can calculation its value ??? and How we can set it in program?? the controller have a registry for it? what's the name of it?
