From what I've read, it seems that the LCD fitted to the QVGA base board on the MCB2470 has its own controller and frame buffer, but the example code from NXP and EA disables this and uses the LPC2478 controller and external RAM instead. I'd like to use the LCD internal frame buffer and controller but can't make out from the example code or SSD1289 controller chip documentation how to do it. Anyone done this, or know if it's possible?
