I have problem in using isr_evt_set interrup handler sent event to task with isr_evt_set but task did not receive event or consumed much time
LM3S Luminary chip has NVIC and I didnt enable interrupt in user mode
at NVIC How do I set irq-handler with keil rtx is it reserved sections for nvic handler? does it need irq stack?
at startup code
export __Vectors __Vectors ... dcd irq1handler dcd irq2handler ...
at task
void irq2handler(void) __irq { isr_evt_set(INT_SIGNAL, handler_task); } __task void handler_task(void) { while(1) { os_evt_wait_or (INT_SIGNAL, 0xffff); do_start_handler(); } }
irq2handler work with privilege mode but do_start_handler is not working
help me..
