I have a problem with GNU compiler . i run my code from Real view compiler to GNU compiler i have gotten many errors. i could set the path of cygnus folder and GNU tool prefix as arm-uclibc. After that also i faced problem .please tell the reference manual for GNU compiler.
among others, you need to rewrite your startup file.
Note that GCC is not a Keil product, and is no longer supported by Keil - so this is not the best forum for GCC questions! See: http://www.keil.com/forum/docs/thread12738.asp
GNU Documentation: www.gnu.org/.../doc.html
GCC is under "Software Development" at: www.gnu.org/.../manual.html
