Warning: require_once(C:\Inetpub\wwwrootrdparty\pear\Log.php) [function.require-once]: failed to open stream: Invalid argument in C:\Inetpub\wwwroot\Logger.php on line 5 Fatal error: require_once() [function.require]: Failed opening required 'C:\Inetpub\wwwrootrdparty\pear\Log.php' (include_path='.;C:\Php\php5\..\include_lib;C:\Php\php5\PEAR') in C:\Inetpub\wwwroot\Logger.php on line 5 iam new for php, iam integrating iis with php. this build is already in apache tom cat server, can any tell who to retify this error
"...iam integrating iis with php."
... and how does that relate to Keil products?
Do you mean "iis" as in Microsoft's Internet Information Services?
If so, that's a Microsoft product, and has nothing whatsoever to do with Keil! In that case, this is the wrong forum for you! You should go to: http://www.iis.net/
Specifically, http://php.iis.net/
