I am trying to make typedef a 64-bit unsigned and getting error. How do I typedef 64-bit
typedef unsigned long long QWORD; // 64-bit unsigned
error C141: syntax error near 'long'
Have a look at this link: http://www.keil.com/support/docs/1677.htm
If you need a 64-bit integer, you will have to implement that logic yourself. Do you need full math support, or is it just for some kind of counter?
