How to Select a column address in OLED
Hi all,
I am new to using the OLED.
I am able to Display the "Hello" message in Different page of the OLED.
But i cannot select the Colomn address.
I have given the Lower column address setting as 0x02 and Higher column address setting as 0x10.
How to select the particular column address for printing the "Hello" message.
With regards,
Murthy.R
  • There is no such thing as "the OLED"
    There are very many different manufacturers, all of whom make very many different "OLED" products - so it is impossible to answer your question without knowing precisely what particular "OLED" device you have!
    But this will be stated in the Datasheet for your "OLED" - so, just study the Datasheet, and do whatever it tells you!
    Note that this has nothing to do with ARM or Keil - the "OLED" works the same way irrespective of what controller you have, and what tools you use to create your software!
