In my project i have one main file(it has the main function) and five files which contain a function each and is called from main function one by one. When i use the following setting in link file COMMON{startup.obj}, COMMON{protect.obj}, COMMON{l51_bank.obj}, COMMON{main.obj}, BANK1{file_1.obj}, COMMON{file_2.obj}, COMMON{file_3.obj}, COMMON{file_4.obj}, COMMON{file_5.obj} TO clk_freq BANKAREA(0x8000, 0xFFFF)
and after that i use follwoing commands to generate the bin file.
LX51 @link_CLK.lnk
OHX51 clk_freq HEXFILE(clk_freq.Hxx) H386 MERGE32K hexbin2 clk_freq.hxx clk_freq.bin i 0000 7fff 2
the size of file is as follows clk_freq (OMF51 obj module) --> 22kb clk_freq.hex --> 6kb clk_freq.bin --> 33 kb The size are fine and as per expected, but when i use the following settings in link file
COMMON{startup.obj}, COMMON{protect.obj}, COMMON{l51_bank.obj}, COMMON{main.obj}, COMMON{file_1.obj}, COMMON{file_2.obj}, COMMON{file_3.obj}, COMMON{file_4.obj}, COMMON{file_5.obj} TO clk_freq BANKAREA(0x8000, 0xFFFF)
that is all files in common bank than the bin file is not generated, the file size are as follows
clk_freq (OMF51 obj module) --> 20 kb clk_freq.hex --> 1 kb clk_freq.bin --> 0 kb
can anyone please tell me why the binary file is not generated when all the files are kept in same bank.
Have you checked what's actually in that Hex file?
What build messages do you get? Do they indicate any problems?
this is the build message i get, it shows no problem as such
Build target 'Target 1' compiling main.c... assembling PROTECT.A51... assembling STARTUP.A51... assembling L51_BANK.A51... compiling file_1.c... compiling file_2.c... compiling file_3.c... compiling file_4.c... compiling file_5.c... creating library sample.LIB... TRANSFER "main.obj", "PROTECT.obj", "STARTUP.obj", "L51_BANK.obj", "file_1.obj", "file_2.obj", "file_3.obj", "file_4.obj", "file_5.obj" TO "sample.LIB" LIBX51 LIBRARY MANAGER V4.24 COPYRIGHT KEIL ELEKTRONIK GmbH 1987 - 2002 User command #1: C:\UserData\DECT_Handset\transmit\sample_project\LNK_SampleApp.bat C:\UserData\DECT_Handset\transmit\sample_project>LX51 @link_CLK.lnk LX51 LINKER/LOCATER V4.34a - SN: K1CBF-1A7HTE COPYRIGHT KEIL ELEKTRONIK GmbH 1995 - 2008 @link_CLK.lnk COMMON{startup.obj}, COMMON{protect.obj}, COMMON{l51_bank.obj}, COMMON{main.obj}, COMMON{file_1.obj}, COMMON{file_2.obj}, COMMON{file_3.obj}, COMMON{file_4.obj}, COMMON{file_5.obj} TO clk_freq BANKAREA(0x8000, 0xFFFF) CODE MAP IXREF LI PUBLICS SYMBOLS NOAJMP NOSORTSIZE DW(8) CLASSES( XDATA (X:0x0000-X:0x47FF), PDATA (X:0x4700-X:0x47FF), CONST (C:0x0000-C:0x7FFF), HCONST (B1:0x8000-B1:0xFFFF, B2:0x8000-B2:0xFFFF, B3:0x8000-B3:0xFFFF, B4:0x8000-B4:0xFFFF, B5:0x8000-B5:0xFFFF, B6:0x8000-B6:0xFFFF, B7:0x8000-B7:0xFFFF, B8:0x8000-B8:0xFFFF, B9:0x8000-B9:0xFFFF, Ba:0x8000-Ba:0xFFFF, Bb:0x8000-Bb:0xFFFF, Bc:0x8000-Bc:0xFFFF, Bd:0x8000-Bd:0xFFFF, Be:0x8000-Be:0xFFFF, Bf:0x8000-Bf:0xFFFF) ) ;;SEGMENTS (?CO?dect_step8(B1:)) *** WARNING L16: UNCALLED FUNCTION, IGNORED FOR OVERLAY PROCESS NAME: _UART_OUTSTR/MAIN *** WARNING L16: UNCALLED FUNCTION, IGNORED FOR OVERLAY PROCESS NAME: _UART_OUTPTR/MAIN *** WARNING L16: UNCALLED FUNCTION, IGNORED FOR OVERLAY PROCESS NAME: _FUNC1/MAIN *** WARNING L16: UNCALLED FUNCTION, IGNORED FOR OVERLAY PROCESS NAME: _DELAY_UC/MAIN Program Size: data=158.1 xdata=47015 const=8 code=1872 LX51 RUN COMPLETE. 4 WARNING(S), 0 ERROR(S) User command #2: C:\UserData\DECT_Handset\transmit\sample_project\BIN_SampleApp.bat C:\UserData\DECT_Handset\transmit\sample_project>OHX51 clk_freq HEXFILE(clk_freq.Hxx) H386 MERGE32K Extended 8051/251 Object to Hex File Converter V1.36b COPYRIGHT KEIL ELEKTRONIK GmbH 2000 - 2006 GENERATING INTEL H386 FILE: clk_freq.Hxx C:\UserData\DECT_Handset\transmit\sample_project>hexbin2 clk_freq.hxx clk_freq.bin i 0000 7fff 2 ***** HEX to BIN file converter V3.35B ***** INTEL Extended Hex to Binary converter Convert complete "sample.LIB" - 0 Error(s), 0 Warning(s).
and the contents of hex file are
00000000 3A 30 30 30 30 30 30 30 31 46 46 0D 0A :00000001FF
If it is uncalled comment it out. If it is call indirectly declare it correctly
it is not a indirectly called function.............i commented it but still not able to generate bin file
