I am working on LPC2378STK board Now I am trying to establish a connection between ARM board and PC. I have a sample code.But it does not have any IP address setting. thank you
So you need to spend some time studying that sample code to find out how gets or sets an IP address...
ok i wil try can u post link to sample code or upload sample code itself thank u
Bt u z u lrdy hv d smpl cde?!
The Keil TCP/IP stack is not included with the compiler, so you need a commercial add-on license to compile your own examples with the Keil TCP/IP stack.
There are a couple of examples that you get together with the compiler, but you will not be able to rebuild them.
