I am trying to write my own FLASH programmer on a Cypress USB 8051 chip that will program a SiLabs 8051 using their C2 Interface. I have written a macro that simply sets a pin low in the first statement and high in the second statement (to create the strobe signal that I connect to the SiLabs C2 clock input line). When I run the debugger on this code, this pin transition only occurs one times and then all other pin strobes are seemingly ignored or optimized out. I have the compiler set to Optimization 0 but these pin operations are still ignored. Has anyone run into this problem? The macro I set up looks like:
#define Strobe_C2CK C2CK = LOW; C2CK = HIGH
and I have also tried:
#define Strobe_C2CK C2CK = (volatile)LOW; C2CK = (volatile)HIGH
and the C2CK value is defined as:
#define C2CK PB0
Finally, the code that uses the above macros is:
void C2_Write_Address(uint8 address) { uint8 i; // First send the start field for the ADDRESS Write command Strobe_C2CK; // Send the instruction field (0b11, LSB first) for the command C2D = HIGH; C2D_Driver_On; Strobe_C2CK; C2D = HIGH; Strobe_C2CK; // Send the address field one single bit at a time for ( i = 0; i < 8; i++ ) { C2D = ( address & 0x01 ); Strobe_C2CK; address >>= 1; } // Send the stop field for the command and disable the C2 driver pin C2D_Driver_Off; Strobe_C2CK; } // End of function
Thank you for the help.
-Thomas
My suggestion is that you try to get your code working without any macros first. Also post your code here without any macros if it is still not working.
Hello.
can you do assembly ? write it by assembly.
but if you want to use the c. is yo're C2CK declared volatile ?
Zeusti.
always yo're freind.
(now approved by Maj. Hugo Samson)
