New to Keil software, ARM processor & J-Trace from Segger: When I try to flash Keil development board ver 3.1 via EMT or the JTAG port using Segger's J-Trace, the following message is displayed in uVision:
Build target 'LPC2378 Flash' assembling LPC2300.s... compiling Retarget.c... compiling Serial.c... compiling Blinky.c... compiling LCD_4bit.c... compiling IRQ.c... linking... Program Size: Code=3870 RO-data=98 RW-data=12 ZI-data=1292 ".\Flash\Blinky.axf" - 0 Error(s), 0 Warning(s). Load "C:\\Documents and Settings\\Administrator\\My Documents\\Angelo\\Project\\Ver00\\Blinky\\Flash\\Blinky.AXF" VTarget = 3.313V Info: TotalIRLen = 4, IRPrint = 0x01
Info: Halting CPU core DLL version V3.90d, compiled Sep 1 2008 13:56:39 Firmware: J-Trace ARM Rev.1 compiled Sep 5 2007 06:57:41 Hardware: V1.00 Hardware-Breakpoints: 2 Software-Breakpoints: 2048 Watchpoints: 0 Found 1 JTAG device, Total IRLen = 4: Id of device #0: 0x4F1F0F0F ARM7 identified. JTAG speed: 5 kHz Info: TotalIRLen = 4, IRPrint = 0x01
***JLink Warning: RESET (pin 15) high, but should be low. Please check target hardware. JTAG speed: 1000 kHz Erase Failed!
Do I look for hardware fault or software setting?
Any help will be appreciated. Thanks in advance.
