How to Use 8051 emulator
I am new to In circuit emulators. I just got the 8051 emulator from wellon. I don't know how to use and get best out of it.
They gave a documents for installation with Keil IDE and it is working, but to get results, how i check in Keil UV to find bugs in my code.
I think all the ICE are working on the same pattern, so if you have some documents, articles for best uses of 8051 emulators, please suggest
Wellon link : www.jywdz.com/.../index.asp
  • Each and every ICE I have used (5 or more) has been totally different from the others. Thus the only resource you have is the manual for the emulator you have.
    If you got the emulator without a comprehensive manual (file or print), you just kicked yourself in the butt. The emulator manufacturer should have a helpline, try that.
