VHDL code of pulse width modulation PWM
i'm writing a code of a 4 bit pulse width modulator with the following code
llibrary ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
entity PWM is port(CLK : in std_logic; D : in std_logic_vector (3 downto 0); PWM : out std_logic);
end PWM;
architecture Behavioral of PWM is
signal tmp : std_logic_vector(3 downto 0);
signal up_down : std_logic;
signal Oup : std_logic;
signal TC : std_logic;
begin process (CLK, TC, tmp) begin if (CLK'event and CLK = '1' and TC = '0') then if (up_down = '1') then tmp <= tmp + 1; elsif (up_down = '0') then tmp <= tmp - 1; end if; elsif (TC'event and TC = '1') then tmp <= D; Oup <= not Oup; PWM <= Oup; up_down <= Oup; elsif (tmp'event and tmp = "1111") then TC <= '1'; elsif (tmp'event and tmp = "0000") then TC <= '1'; end if; end process;
end Behavioral;
but i keep getting the following error when viewing the RTL schematic
ERROR:Xst:2358 - "C:/Users/Mazen/Documents/VHDL Projects/First/PWM/PWM.vhd" line 45: Operands of <AND> are not of the same size.
any ideas ??
  • Keil? A VHDL product?
    You have run off course. The link is here:
    http://dev.null.org/
  • A quick re-write of your code turns into this:
    llibrary ieee;
    entity PWM is port
            CLK : in  std_logic;
            D   : in  std_logic_vector( 3 downto 0 );
            PWM : out std_logic
    end PWM;
        signal tmp     : std_logic_vector( 3 downto 0 );
        begin process( CLK, TC, tmp )
           begin
               if( CLK'event and CLK = '1' and TC = '0' ) then
                       if( up_down = '1' ) then
                           tmp <= tmp + 1;
                       elsif( up_down = '0' ) then
                           tmp <= tmp - 1;
                       end if;
               elsif( TC'event and TC = '1' ) then
                   tmp     <= D;
                   Oup     <= not Oup;
                   PWM     <= Oup;
                   up_down <= Oup;
               elsif( tmp'event and tmp = "1111" ) then
                   TC <= '1';
               elsif( tmp'event and tmp = "0000" ) then
                   TC <= '1';
               end if;
       end process;
    end Behavioral;
    Let me think about it a bit. But it could be in the tmp'event statement where it is looking for any transition in a single specific bit transistion of the array and then being 'AND'ed with the full array.
    Its late here, and I don't want to build a special project in my Actel's Libero FPGA IDE to figure it out right now. (1AM EST---my kid's baseball game is at 9AM ... in 8 more hours).
    (Yes, I know its not Keil, but it is an interesting question).
    Does my 're-write' match your code?
    --Cpt. Vince Foster
    2nd Cannon Place
    Fort Marcy Park, VA
  • Again its late on a Sunday evening, but I wanted to know if my answer helped. (I'm too busy to actually vet it properly at the moment).
    --Cpt. Vince Foster
    2nd Cannon Place
    Fort Marcy Park, VA
