Do you think it is difficult to use source version control system of firmware develop or personal software develop? For most source version control system you need to setup a server first, which is make version control more expensive and difficult.
Main features of EzSVCS, for download please visit: http://easysoft.cc >>Not require a server which is more convenient. >>Embedded syntax editor supports lots of language such as c, cpp, c#, asm, pascal etc. >>Embed itself to "Keil uVision", You can do version control with menu of "Keil uVision". You can also use it for "MPLAB", "AVR Sutdio", "ICC AVR", "Visual C++", "Visual Basic", "Delphi", etc. >>Useful difference comparer for you check your changes. >>Not require all project file in the same directory of your hard disk. >>It's green, install is no need. After you copy it to your system. Even after your system crash, it could keep your source files.
